Tractor Talk Discussion Forum
Engine Missing Plugs, wires???
G in Minnesota
06-23-2007 21:00:33
I have a tractor that has one or two cylinders missing. When I pull the spark plug wire out of the distributor, and it arcs about 1/2 inch, they start firing. Switching the wires with other ones that fire does not seem to matter. I changed the gap on one of the plugs to be smaller 0.016 and it started firing. The other one did not matter much with a smaller gap. Any ideas what the problem may be?
G in Minnesota
06-26-2007 07:35:02
 Re: Engine Missing Plugs, wires??? in reply to G in Minnesota, 06-23-2007 21:00:33
I put in the new plug and copper wires and it runs great! Thanks for the suggestions!
Marv
06-24-2007 07:57:38
Check for a bad/leaking manifold gasket. Spray some WD40 on the gasket and if you notice a change in engine sound the gasket is leaking air.
Janicholson
06-24-2007 05:47:48
BuickandDeere has the answer. As you pull off the wire, the spark voltage goes up radically. This increase causes the spark plug to fire even when contaminated with a carbon track. New plugs will make it work (for a while). Adjusting the carb, or rebuild of engine may be needed if it smokes at all. JimN
G in Minnesota
06-23-2007 21:59:17
Any suggestions on solid core wire source? These do not appear to be.
RustyFarmall
06-24-2007 05:01:40
 Re: Engine Missing Plugs, wires??? in reply to G in Minnesota, 06-23-2007 21:59:17
Those wires are available right here on YT, or try ebay, or send me an e-mail.
Walt Davies
06-23-2007 22:32:55
Napa has copper core kits in both 4 and 8 wire system. I alway buy the 8 because I can do 2 4's with it for one a few dollars more.
Walt
Jeff McBride
06-23-2007 21:43:15
Have a Super M that done the same thing. I replaced the plugs and it done fine. The bad part is the plugs that where in it were only a month old. They were autolites
buickanddeere
06-23-2007 21:09:15
Replace, do not clean modern spark plugs. Just guessing here as I have no idea of the engine make, model, condition etc.Odds are either new Autolite 216 or 437, 3116 or 378 will be a place to start. If the wires are not solid core, non resisitor units. Toss them as well. Is the engine burning oil,running rich or being operated too cold?
