Tractor Talk Discussion Forum
Allis B Mag.
Herb (Maine)
06-24-2007 05:50:50
I have a 1946 Allis model B that recently begun to run a little rough of and on. Then one day just wouldn"t fire at all. After some investigation I found the little center pin on the outer Mag cover had broken off. I assume this is the problem. My question is this. The tractor has been converted to a 12 volt system. It also has had a coil, and condensor installed. They basically drilled a hole through the side of the Mag and wired the coil and condensor to the inside of the Mag. with a key (on off switch) wired direct to the coil. I am thinking about putting it back to a straight mag with no coil. Will the mag work on a 12 volt system and is it difficult to switch it back?
Paul from MI
06-25-2007 04:21:09
 Re: Allis B Mag. in reply to Herb (Maine), 06-24-2007 05:50:50
Another option might be to replace the mag with a distributor as was used on later Allis(and other) tractors. May find one used at a decent price. Since the tractor is already converted to 12V you probably arent too concerned with originality and you can always convert it back later if you want. GBood Luck,
Paul
Herb (Maine)
06-25-2007 05:34:20
 Re: Allis B Mag. in reply to Paul from MI, 06-25-2007 04:21:09
Thanks Paul. This is an option I hadn't thought of.
Keith-OR
06-24-2007 14:39:56
Here is a great site for Allis info. I am putting up the mag. ingo page. You need other info just go to his other pages...HTH
Keith & Shawn
Keith-OR
06-24-2007 14:50:47
 Another Allis info site in reply to Keith-OR, 06-24-2007 14:39:56
Herb, I have several others if you need more info.
Keith & shawn
Herb (Maine)
06-25-2007 04:08:31
 Re: Another Allis info site in reply to Keith-OR, 06-24-2007 14:50:47
Thank you Keigh and Shawn for the information it is very helpful and greatly appreciated.
RAB
06-24-2007 10:17:23
You need to know whether the ignition system was just 'changed' when the new 12 volt system was added or because the mag was no good. I would guess the latter. As stated previously, you can just reinstall the mag system. I would look for a replacement in good working order.
Regards, RAB
old
06-24-2007 08:35:07
As Rusty says. Also sounds like either way you need a new cap for that mag and they are not cheap. A manual also would help you a lot. If you don't have a manual for the mag drop me an e-mail and I'll send you a manaul for that mag since I have one in the computer some one else sent me
Herb (Maine)
06-25-2007 04:06:55
 Re: Allis B Mag. in reply to old, 06-24-2007 08:35:07
Thanks for your reply Old. I am going to purchase a new cap and I do not have a Manual for the mag so if you wouldn't mind sending that along it would be greatly appreciated. Thanks again for all your help.
old
06-25-2007 08:15:12
 Re: Allis B Mag. in reply to Herb (Maine), 06-25-2007 04:06:55
I'd be happy to send you the manual but to do so you have to send me an e-mail so I can sned it to you
RustyFarmall
06-24-2007 06:12:19
A fully functional magneto creates its own electricity. It is totally independent of the tractor electrical system. The magneto does not care if the tractor has been converted to 12 volts or if it is still the original 6 volt system. The magneto does not care because it is not connected to any part of the tractor electrical system. In fact, the magneto will create spark and fire the engine even if the tractor does not have a battery or generator or alternator.
Herb (Maine)
06-25-2007 04:11:09
 Re: Allis B Mag. in reply to RustyFarmall, 06-24-2007 06:12:19
Thanks Rusty for this information, it's greatly appreciated.
