Tractor Talk Discussion Forum
Case DC-4
jonathon munoz
06-24-2007 06:56:18
I have a dc-4 case and the tractor misses and has no power. I took valve cover off and 3 out of the four exhaust valves are .012-.090 down past the retainer. The rocker arm hit the spring retainer all the time and puts pressure on spring. I can see a wear spot on rocker arm from retainer. What do you think happened? Are the valve keepers wore to much and are sunk in to far in spring retainer?
Walt Davies
06-24-2007 07:31:10
 Re: Case DC-4 in reply to jonathon munoz, 06-24-2007 06:56:18
I wouldn't worry to much about what's wrong because the head has to come off and then be sent in to be rebuilt anyway. Sometimes it the the only cure.
Walt
