Tractor Talk Discussion Forum
Drill sizes for taps
Farmall Md nut
06-24-2007 10:42:57
I was goin thru some of my charts, and figured some of you can use this info on drill sizes for taps.
Thread----- -Drill_____ __Thread----- ----- Drill
0-80----- ---3/64_____ ____1/4-20----- ----- -7
1-64----- ---53_____ _____ 1/4-28----- ----- -3
1-72----- ---53_____ _____ 5/16-18----- ----- F
2-56----- ---51_____ _____ 5/16-24----- ----- I
2-64----- ---50_____ _____ 3/8-16----- ----- 5/16
3-48----- ---5/64_____ ____3/8-24----- ----- -Q
3-56----- ---46_____ _____ 7/16-14----- ----- U
4-40----- ---43_____ _____ 7/16-20----- ----- W
4-48----- ---42_____ _____ 1/2-12----- -----27/64
5-40----- ---39_____ _____ 1/2-13----- -----27/64
5-44----- ---37_____ _____ 1/2-20----- -----29/64
6-32----- ---36_____ _____ 9/16-12----- ----31/64
6-40----- ---33_____ _____ 9/16-18----- ----33/64
8-32----- ---29_____ _____ 5/8-11----- -----17/32
8-36----- ---29_____ _____ 5/8-18----- -----37/64
10-24----- --25_____ _____ 3/4-10----- -----21/32
10-32----- --21_____ _____ 3/4-16----- -----11/16
12-24----- --17_____ _____ 7/8-9----- ----- 49/64
12-28----- --15_____ _____ 7/8-14----- -----13/16 1-8----- ----- --7/8 1-12----- ----- 59/64 1-14 15/16
williamf
06-25-2007 05:02:41
 Re: Drill sizes for taps in reply to Farmall Md nut, 06-24-2007 10:42:57
Thanks - That's a post that goes into my "How To - Mechanical" folder.
Wm
Mike in Ohio
06-24-2007 17:33:56
Thaks alot I'm going to print this out and put copys with my taps and drills and drill press and every place else I can think of so I can find one of them next time I need it. Thanks again Mike
Farmall MD nut
06-24-2007 10:47:10
Sorry for all the dashes and lines, but that's the only way it would format right. It won't let put spaces in between the numbers. Also, the 1-8, 1-12, and 1-14 should be below the 7/8, not the 12-28. Hope you can make it out.
Doug
