Tractor Talk Discussion Forum
Repair Manual for Ford 5550 4 cylinder diesel backhoe
Robert Carden
06-27-2007 17:37:59
I have a Ford 5550 4 Cylinder Diesel backhoe/front end loader. The water is mixing with the transmission fluid. I would like to know what causes this, and would also like to find a Repair Manual that I can buy for this tractor. Any help would be appreciated. Thank you.
MJ in the UK
06-28-2007 02:48:34
 Re: Repair Manual for Ford 5550 4 cylinder diesel backhoe in reply to Robert Carden, 06-27-2007 17:37:59
Hi Richard, i would think your radiator is leaking into your oil cooler wich is built onto the bottom of the radiator. MJ
L:anse
06-27-2007 18:46:34
Groovy tractor... I'd say its the transmission itself. The case could be cracked or a bolt could be lose or something little like that. If there are anything like that-I'd try to put some sealent or something on all bolts and screws-but only if tightning everything dont work.
I am no expert, these are just some ideas.
