Tractor Talk Discussion Forum
ot truck tire conversion
Dale L
06-28-2007 09:07:36
I have an old ,50 ford f-1 that has 6.00-16 tube tire's does any one know what tubles tire number is the same size?
happysmith
06-30-2007 15:40:11
 Re: ot truck tire conversion in reply to Dale L, 06-28-2007 09:07:36
Try LT235/85R16.
They are load range D (10 ply rated) and will carry about 3000 lbs each.
They are tall like the old tires yet narrow in width.
Should look a lot like the originals.
Dale L
06-29-2007 15:48:21
Thanks for the replies I'll have to keep looking
DPG
06-29-2007 12:02:51
Look for LT 215 75 R16 usually they are only available in 8 0r sometimes 10 ply, possibly a LT 225 75 R 16 They should be bigger but they are @ the smallest of the current metric sized light-truck tires.
There are a few "passenger sizes that might work. One problem is the passsenger-tire rim "lip" is different than the flange on the "light-truck" rim you are using. I believe that is true for the LT tires I mentioned. So they may fit on the rim but they may not "seat" to the rim properly.
There are a few other sources out there for "older" tires other than Miller. He has a good business in the "older" sizes though. You have to ask people to look for you...some front-counter folks will say "no, not available anymore" just so they don"t have to look-up anything.
Have fun!!
Lanse
06-28-2007 12:15:47
dude, theres this place known as ME Miller tire, online at MillerTire.com you have to look around, but they have reproduction tires for trucks like that, they will send you a catalog
RN
06-28-2007 09:33:59
Check a 155/16- may look a bit small, probably 165/16 tire. Newer tires with lower profiles-70%, 75, 80,85%, slightly fatter footprint. Maybe 175/16-75 profile. RN
