Tractor Talk Discussion Forum
PTO speeds
Ohio novice
06-29-2007 12:49:19
Does a pto turn faster on a live pto than on my to30 that does not have a live pto? I need to travel slow due to hills while bush-hogging but I need the bush-hog to run fast. Grass etc nearly waist high. Thanks larry
Spam is not welcome.
THANKS TO ALL
06-29-2007 17:23:02
 Re: PTO speeds in reply to Ohio novice, 06-29-2007 12:49:19
Thanks guys..Put all together I think I'll keep what I have and use your advice. larry
nballen
06-29-2007 16:28:59
Larry,
Once the grass gets "out-of-hand", and if you aren't able to get a sickle or have someone swath it for hay, about the only thing you can do is:
a) take it in first gear and realize the job will take a while,
b) rent / buy / borrow a tractor that has a better selection of forward speeds,
c) try taking a partial swath, and see if you can handle that in 2nd gear.
Ohio picker
06-29-2007 16:00:33
I really was not comparing tractors just wondering if I would gain pto speed seperate in some way if I had a live pto. 2nd gear is too fast and 1st is too slow on my TO20 with a TO30 engine. I thought there might be a way to overcome that. Thanks larry
K.B.-826
06-29-2007 16:25:02
 Re: PTO speeds in reply to Ohio picker, 06-29-2007 16:00:33
Your best bet would be to find a tractor with better spaced transmission speeds.
Ohio picker
06-29-2007 16:24:23
THANKS TO ALL for you help. I have a lot to think about. larry
mowr
06-29-2007 16:18:35
540 rpm is the standard of the industry for tractors and attachments in this size range. No variations. To remedy your problem you need a bigger tractor with more speeds.
Big Hunter
06-29-2007 14:23:45
downshift
Ohio picker
06-29-2007 15:55:17
 Re: PTO speeds in reply to Big Hunter, 06-29-2007 14:23:45
Thanks Hunter for the advice so quickly.
I was considering buying a tractor with live pto if I would gain anything over downshifting. Is there any gain other than live/notlive?
larry
Big Hunter
06-29-2007 14:23:42
downshift
J Schwiebert
06-29-2007 12:53:44
You ask a loaded question. Standard is 540 plus or minus 10 RPM. Makes no difference if it live or not that is the standard. Now some tractor get that speed at a reduced engine RPM compared to rated engine speed. So what 2 tractors are you comparing?
steveormary
06-29-2007 20:58:43
 Re: PTO speeds in reply to J Schwiebert, 06-29-2007 12:53:44
I think you get 540 pto rpm at about 1500 engine rpm. with your to30.That would be at half throttle+. Go in 1st.gear and take your time. If you start bogging down pull out and take a smaller cut.
steveormary
steveo
06-30-2007 05:35:04
 Re: PTO speeds in reply to steveormary, 06-29-2007 20:58:43
Thanks, I'll do just that and see how it does. larry
