Tractor Talk Discussion Forum
calling Billh or allan in ne
D17 man
07-01-2007 19:05:10
hi i got a question about my 1086. th hydraulics are slow. it wont lift a load unless it's idled up at least 1300 rpm. is it normal or is my pump worn out?
Allan In NE
07-02-2007 03:07:47
 Re: calling Billh or allan in ne in reply to D17 man, 07-01-2007 19:05:10
For sure not normal. It should operate the same at idle or wide open.
Don't know much about those piston pumps on the later models. If yours is an earlier one with gear type pumps, I'd be for looking at that pump back under the left rearend area.
That pump handles the hitch and remotes only.
Allan
Billeh
07-01-2007 20:26:42
Might be. Is it full of hydraulic oil? The filter also might be in need of replacing. Does your steering ever become hard to steer? On those tractors the hydraulic pump also controls the steering, clutch and brakes. The pto is on a seperate drive.
