Tractor Talk Discussion Forum
gear noise on 600 ford
n8terry
07-03-2007 18:58:16
I have gear noise in High gear only. Is this a gear worn or a bearing?
What happens if I do nothing to it?
soundguy
07-03-2007 20:51:34
 Re: gear noise on 600 ford in reply to n8terry, 07-03-2007 18:58:16
What kinda oil you got in the trans? IF UTF, drain and add 85/140 gear oil and see what that gets you.
Soundguy
alan bane
07-03-2007 19:42:20
I had an excellent Super C Farmall that had that whine in high gear and nothing in the other gears.I owned and used it for about 15 years and it never got any worse. I don't know the cause unless it would be wear but it was the least used gear. I have a SUPER A now that makes that noise in reverse.If I were you I'd put new gear oil in it and use it and not worry about the gear noise.When it goes out , fix it. Just an opinion.
