Tractor Talk Discussion Forum
Oliver 1650
Jimmy Ray in Ia
07-04-2007 07:50:29
Hi Everyone
Recently purchased an Oliver 1650. Fired right up at the previous owners place. Had it painted and now is very cold blooded and gets flooded easy. Looking for some advice before it hits the shop Many thanks Jimmy in Ia
J Schwiebert
07-04-2007 08:14:38
 Re: Oliver 1650 in reply to Jimmy Ray in Ia, 07-04-2007 07:50:29
Sounds to me like you have an ignition problem. If you have the flooded condition you must not begetting a good spark. Have you checked the spark? What did the plugs look like? Does it has the orignal Holly distributor? If so, check the point gap too. You should have a good blue spark that jumps 3/8 of an inch.
flying belgian
07-04-2007 08:02:18
Go through and clean carb.
centralilbaler
07-04-2007 07:55:46
My 1650's cold blooded too. I just try and make sure the carb is redone about every year and keep fresh gas in it
