Tractor Talk Discussion Forum
Farmall M problem
Nebraska Kirk
07-06-2007 06:19:39
I just helped my brother rebuild the engine in his M. After the initial warm up period I removed the valve cover to retorque the head and reset the valves. That is when I discovered that the #6 push rod was dry where it meets the rocker arm. I oiled it, put the cover on and ran it for a while, then removed the cover and checked it again. Dry again! For some reason oil is not getting splashed on that particular push rod :-( Any ideas?
Marv
07-06-2007 06:31:42
 Re: Farmall M problem in reply to Nebraska Kirk, 07-06-2007 06:19:39
Use a small drill bit to unplug the oil line on the rocker arm. Oil is forced out of this oil port. Run the tractor with the valve cover off and you will see oil being forced out of the working rockers. Marv
dhermesc
07-06-2007 07:39:21
 Re: Farmall M problem in reply to Marv, 07-06-2007 06:31:42
It is cool watching those solid lifter engines run without the valve cover. I had to do the same thing for a similar problem on my old Ford 223.
Nebraska Kirk
07-06-2007 07:04:32
Thanks! That was the problem!
