Tractor Talk Discussion Forum
574 Internationsl
Mickey Hughes
07-07-2007 12:55:46
The PTO on my 574 is giving me trouble. When I engage the bush hog it seems to be fine but when I put it into the weeds the PTO will slow and then stop. Any suggestions?
thanks
Mike (WA)
07-08-2007 08:48:55
 Re: 574 Internationsl in reply to Mickey Hughes, 07-07-2007 12:55:46
PTO is activated hydraulically- change filter if you haven't done so in awhile, as they get clogged with crud (especially if the oil gets a little moisture in it), and you can't pump enough juice, even if the level is OK.
M Hughes
07-08-2007 12:50:18
 Re: 574 Internationsl in reply to Mike (WA), 07-08-2007 08:48:55
thanks! I will look into this.
georgeky
07-07-2007 17:21:13
Is the tractor low on hydraulic oil? May need to adjust the linkage. Sounds like it may not be going all the way in.
M Hughes
07-08-2007 12:53:02
 Re: 574 Internationsl in reply to georgeky, 07-07-2007 17:21:13
Thanks I will check the linkage that just may be some of the trouble. I think I will also just go ahead and change oil and filter and maby that will take care of it.
