Tractor Talk Discussion Forum
Long 1199 Backhoe
John Martin
07-10-2007 08:03:47
Posted on the Crawlers, Dozers, Backhoes board and didn"t get a reply, so trying here. I inherited a Long 445 tractor with a front loader and backhoe. The backhoe is a 3-pt hitch attachment, and sat idle for more than 15 years. I got it hooked up and moved it to a place where I can work on it, and am now needing parts and manuals.
The backhoe is an 1199 model. The pto pump has two main parts, the actual pump, and the gear box that attaches to the tractor pto shaft. The pto pump was detacthed from the pto gear box, and the gear that connects the splined pump shaft to the pto gear box is missing.
I obvouisly need the gear, but I"d like manuals for the 1199, which I assume would inlcude the pto pump information. Can"t seem to find them online anywhere.
Thanks for any help.
aaron smith
08-15-2007 19:50:52
 Re: Long 1199 Backhoe in reply to John Martin, 07-10-2007 08:03:47
i run my 1199 on my remotes if your tractor has them you wont need the pump
Weldon K
07-10-2007 18:58:28
I have a Long model 1199-B backhoe. Long Manufacturing Co ( now FARMTRAC )in Tarboro NC built the backhoes.
I am in North Carolina, I order parts from:
Long Equipment Co. Inc. 1201 West Northern Boulevard Tarboro NC 27886
Tel. (252)823-1163 or 1-800-468-2012 (got through on the 800 # last week but not today- had to use regular 252 # )
Call them,they can get you in touch with Farmtrac if needed.
I have a manual,if you need some pages, I can e-mail them to you.
John Martin
07-11-2007 05:46:06
 Re: Long 1199 Backhoe in reply to Weldon K, 07-10-2007 18:58:28
Weldon,
Thanks for the information and the offer of an email. Does the 1199-B use a pto driven hydraulic pump? If so, it may be the same as mine.
Currently I'm rebuilding the pump assembly, and as I mentioned before, I'm trying to locate the pinion gear that connects the splined pump shaft to the pto gear box. Any drawings or parts lists would help a lot.
Thanks for the help.
IH2444
07-10-2007 08:42:49
Long is now Farmtrac ?
