Tractor Talk Discussion Forum
OT Forums fo Chevy truck repair??
Steve in Mo
07-13-2007 10:05:27
I have a bad short in my 96 Chevy 1/2 ton truck. Looking for a fourm that could offer me some help finding it. I have replaced the alternator as suggested in a eairler post but it still runs the battery down.
oldrustycars
07-13-2007 15:11:23
 Re: OT Forums fo Chevy truck repair?? in reply to Steve in Mo, 07-13-2007 10:05:27
www.chevytalk.org
I just use a test light, remove the neg. cable, stick the test light between the cable and and the neg. terminal, then remove the fuses as has been suggested. i once had the glove box light staying on...only found that after i shut off the garage lights at night.
2t2@ia
07-13-2007 11:01:30
This may already have been suggested. Try using an ampmeter. Disconnect the neg battery terminal. Check the current draw. Remove fuses one by one from the fuse block. At the point where the current draw stops, that should be the circuit that is causing the trouble. That will narrow it down somewhat. On more than one vehicle, the radio has been the problem for us. Hope this helps.
Maark
07-13-2007 10:54:42
Be sure to have your battery checked. I bought a new one at Wal-mart. It didn't last 2 months , it had a shorted cell.
