Tractor Talk Discussion Forum
John Deere 30 series lighting upgrade
DJL
07-13-2007 21:21:07
I"ve got a JD 4030D, and need a little better lighting than just the two lights on the fenders, especially when I have the loader on it. I"ve seen some 40 series tractors, like 4440 with the light bar that looks like the later 55 series, the one that has three lights and looks built into the front nose piece between the fuel tank and the hood. Right where the yellow stripe is. I really like the way this looks, makes the tractor look a bit more modern and think would give a little better illumination for me. The question is, was this a factory option or an add-on from the dealer? Do you think i could just order the assembly from deere for a 4055 and cut to fit in my 4030?
Thanks
DJL
McFarmer
07-14-2007 10:14:15
 Re: John Deere 30 series lighting upgrade in reply to DJL, 07-13-2007 21:21:07
We upgraded our 4030 and 4430 to the 40 series lights. One more in the front and one on top of the fender. Easy to do and the extra in front, when useing halogens, really makes a difference.
matthies
07-14-2007 05:23:55
They weren't a thought till the 50 series, but think Deere now offers them for the older tractors. I will agree they do look good, but not bright enough for much good. Change the ones you have now with a halogen bulb from a newer tractor, if that isn't enough then add some more lamps.
