Tractor Talk Discussion Forum
Re: OT Nitrogen in Tires
ErnieDD
07-14-2007 18:22:06
I would say the dealer's gauge is off, if you have two that read the same and the tires are at the same temperature.
The main benefit of nitrogen is it inflates the dealers bottom line. The Nitrogen molecule is a little larger than oxygen, so theoretically the gas diffuses a little slower out of the tire. So check 'em once a month and keep the $20.
remember you have a 80% nitrogen fill to begin with
BarryfromIA
07-14-2007 19:03:04
 Re: OT Nitrogen in Tires in reply to ErnieDD, 07-14-2007 18:22:06
Some weekend dirt track racers use it because a tank in the trailer is handier than a compressor. Also a rumor that it is more stable
Davis In SC
07-14-2007 21:10:10
 Re: OT Nitrogen in Tires in reply to BarryfromIA, 07-14-2007 19:03:04
A nitrogen tank is handy to have.. I get one from the shop sometimes to run an impact where I do not have access to a compressor..
Gerald J.
07-14-2007 19:56:58
Since that tanked nitrogen is dry having no water, there's no water to boil a make steam to vary the pressure. So for racing where tire pressures are critical to survival its a pretty good idea. Otherwise its an expense that you can't prove you paid (unlike a chrome dodad) for.
Gerald J.
