Tractor Talk Discussion Forum
PHOTO - wrapping bales
David in Wales
07-15-2007 11:37:57
third party image
Hi Gang;
This is a McHale wrapper mad ein Ireland, one of the best available here.
The loading cradle picks up a bale from the ground and drops it onto the table for wrapping.
The wrapped bale is just being dropped off.
David
Kent in NB
07-16-2007 05:42:55
 Re: PHOTO - wrapping bales in reply to David in Wales, 07-15-2007 11:37:57
How come the front tires on 4WD tractors wear like that? I have yet to get get a reasonable answer from the factory reps. Most common answer is "not my fault...", "Don't know...", "nothing wrong with it, normal wear pattern...".
Gary from Muleshoe
07-15-2007 13:36:37
While in the USAF I was station in Iceland and I watched them use similar wrapping machine there. I used to amaze me that they were bailing hay in the rain. I learned later what was going on. Thanks for the pictures always enjoy your post.
mitch furness
07-15-2007 13:16:42
Dont think moisture matters if it is aerobic?
RodInNS
07-15-2007 19:33:25
 Re: PHOTO - wrapping bales in reply to mitch furness, 07-15-2007 13:16:42
It's less than desirable. If they're too wet they leach and stink.... and don't ensile properly. It's not that you can't do it, by you often get a rancid smelling feed from it. I've baled in the rain to get finished at times, and had bales that weighed close to a ton from an older Claas. That's an activity that's not high on the "recomended" list of things to do.
Rod
supera3
07-15-2007 13:11:27
I see mud on the tires!
Greg_Ky
07-15-2007 11:46:15
Wrapping soaking wet bales?
third party image
RayP(MI)
07-15-2007 12:19:08
 Re: PHOTO - wrapping bales in reply to Greg_Ky, 07-15-2007 11:46:15
Think that glossiness you are seeing is the plastic used to wrap the bale in the baler, not moisture!
Greg_Ky
07-15-2007 12:27:55
 Re: PHOTO - wrapping bales in reply to RayP(MI), 07-15-2007 12:19:08
dont think so as he was baling in the rain in the previous photo.third party image
