Tractor Engine Coolant?
marty from ny
07-18-2007 05:57:17
i have a Ford 1700, and was wondering what type of coolant to run in it? i wasn't sure if i can run automotive coolant or if there was a special type just for tractors.
marty
LenND
07-19-2007 15:16:30
 Re: Tractor Engine Coolant? in reply to marty from ny, 07-18-2007 05:57:17
If it's an older tractor, gas or diesel it doesn't make much differenc what you use as long as it is strong enough to keep from freezing. If you are in cold country they recommend at least half and half.
souNdguy
07-19-2007 06:42:06
Check your manual to see if you need the anti cavitation/electrolysis addative from CNH.. i think it is something like 'F15'.. etc.. can't remember..
Soundguy
Oldmax
07-18-2007 18:48:52
I have 1715, manual calls for 50-50 mix of ethylene glycol .
green type
07-18-2007 06:12:39
The green stuff
marty from ny
07-18-2007 06:18:17
 Re: Tractor Engine Coolant? in reply to green type, 07-18-2007 06:12:39
Gotcha
Jon Hagen
07-18-2007 06:29:04
 Re: Tractor Engine Coolant? in reply to marty from ny, 07-18-2007 06:18:17
If your tractor is a diesel you want the HD stuff with the correct additive package for diesel engines.
