Tractor Talk Discussion Forum
Isaacson Tracdozer Hydraulic Controller
Vic Bunn
07-19-2007 11:18:14
Can anyone tell me the pressure & flow rate of the Isaacson p/n IMA330 hydraulic pump. It"s on an International TD-14. I"m trying to replace the open center controller (p/n 29D-7) with a single spool up/dn float spring loaded one. The original one has 3/4 ports except for the 1 inch return to the tank. If you can tell me what controller would work without getting hot, I"d appreciate it!
J Schwiebert
07-19-2007 11:23:00
 Re: Isaacson Tracdozer Hydraulic Controller in reply to Vic Bunn, 07-19-2007 11:18:14
If nobody does, there are formulas where you take the old pump and measure it up to get the GPM, Float valves to buy over the counter that size could get interesting. I would do away with the pipe threads as well. I do have a Gresen or a Commercial valve in mind. J.
