Tractor Talk Discussion Forum
JD chain
Lanse
07-24-2007 11:24:46
on my 290 planter, there is these little chains that go between gears. Ay one end a little peice of steel curves around the next link. Anyone know how to open these little *#%&$&@?
Lanse
07-24-2007 13:10:39
 Re: JD chain in reply to Lanse, 07-24-2007 11:24:46
Thanks, you guys are great ;)
Don-Wi
07-24-2007 11:59:48
Sounds like steel detatchable chain. Do as Mike M says, You gotta line up the slots and pound it apart form the side. If you've got small anvil or railroad tie or something else solid to drive against it makes it go a lot easier.
Donovan from Wisconsin
Mike M
07-24-2007 11:39:03
Can't picture what those used ? is it a flat links of chain like on a manure spreader ? if so you hold the one link bend it so the slot lines up with the one next to it and drive it off sideways.It is like spring steel so it pops open and closed. They make a special cast iron tool with a handle on it to hold these. It has spots for I think 3 different sizes.
Loren in Florida
07-24-2007 12:06:19
 Re: JD chain in reply to Mike M, 07-24-2007 11:39:03
third party image
You are correct. Flat link chain. Couple of those tools in the photo ads.
Rich Va
07-24-2007 12:18:38
 Re: JD chain in reply to Loren in Florida, 07-24-2007 12:06:19
We called that thing a chain detacher. I think most of the farmers got theirs when they got a corn snapper. I have two of 'em. I got a chain breaker too,but that's used for roller chain.
