Tractor Talk Discussion Forum
Why 7holes?
Lanse
07-24-2007 13:31:20
I am new to tractors. I was pulling a wagon today and looked back at the drawbar and wondered why it has seven holes. Why does it have seven holes?
Walt Davies
07-24-2007 18:18:19
 Re: Why 7holes? in reply to Lanse, 07-24-2007 13:31:20
Plows and some other equipment will pull the tractor to one side or the other to compensate for this you set the draw-bar to one side or the other until it runs straight. It actually came down from horse drawn equipment. Horse don't pull good to one side or the other.
Walt
RAB
07-24-2007 14:57:28
And for transporting machinery off-set from the tractor so as it will fit through gates etc when gates were only 8 or 10 feet wide or for off-setting so you don't run on the crop just before you cut it or just after you have fluffed up your hay for drying.
LenND
07-24-2007 13:39:37
The amount of holes was determined by the manufacturer I think. It was to mount their own style of machinery. There are usually an odd number because they had to have one in the exact center of the deawbar to pull evenly.
Andy Motteberg
07-24-2007 13:33:49
What kind of tractor? Holes in the drawbar are for mounting implements.
Farmall MD
07-24-2007 13:53:21
 Re: Why 7holes? in reply to Andy Motteberg, 07-24-2007 13:33:49
Or an easy way to offset trailer plows instead of changing wheel width. Doug N
