Tractor Talk Discussion Forum
IH 574 with stuck clutch
andrew kitson
07-25-2007 14:21:02
I have a buddy at work who needs help with is IH 574. The clutch is stuck adn we can"t figure out how to get it free. The last time he just pulled it and it popped free no such luck this time. Can anyone help. I told him to trade in on a JOHN DEERE
Thanks
Andrew
richardinnz
07-26-2007 04:55:36
 Re: IH 574 with stuck clutch in reply to andrew kitson, 07-25-2007 14:21:02
The I-H tractors built at Doncaster, England have an inspection plate under the clutch housing. Remove it and you can undo the bolts holding the clutch cover to the flywheel, disconnect the clutch operating rod, slide the clutch cover & release bearing back along the splines and then free off the plate with a screwdriver, unless you are unlucky and have a siezed spigot bearing you should not have to split the tractor.
old
07-25-2007 15:33:17
Heres a few thing you can try that may work. First block/tie the clutch pedal down when ever parked. Then leave it down and at this time tie it down for a day or so and see it it frees up. If not pull the starter and spray brake cleaner on and on the clutch disk with the pedal blocked down. If you can turn the engine over some as you are spraying it to get the brake cleaner on all parts of the clutch. Another thing you can do is start it up in a high gear or as high as you can and drive it around with the pedal down and it should pop free. But be sure you have a lot of room to drive it and there isn't people or things in the way that you can hit because it will not stop unless you turn it off. Stuck clutches are common on tractors because of the fact they sit at times off weeks and months at a time and rust will stick a clutch fast. BTDT more then once
low budget
07-26-2007 03:46:10
 Re: IH 574 with stuck clutch in reply to old, 07-25-2007 15:33:17
Brake clean has worked well for me too. You could use or make a punch of sorts and tap the pressure plate to help loosen it. Had to do this twice on a Ford 7700 I got last fall. Using it on the round baler this summer hoping to get everything polished up. Better believe I'm going to wire the clutch pedal down this winter when I park it.
dds-inc
07-25-2007 15:26:03
clutch shaft splines could be sticking onto the clutch disk. This can be from rust or twisted splines.
If there is no access plate to see what's going on, split the tractor.
Jim in Ma.
07-25-2007 14:58:21
Andrew - when that happened to mine, I ended up splitting the tractor. A new clutch disk and pressure plate and it has been fine.
I read somewhere that some of those clutch faces and to much metal in them and will rust "stick" to the flywheel.
