Tractor Talk Discussion Forum
backhoe on tractor
alanmeg
07-25-2007 17:05:33
I have 7610 Ford that Im trying to hook a Ditch Witch backhoe onto.The backhoe has three hoses on it,and my tractor has dual remotes.where do the hoses go and what position do I need the levers in on the tractor?Any help would be greatly appreciated>
Mike M
07-26-2007 05:08:07
 Re: backhoe on tractor in reply to alanmeg, 07-25-2007 17:05:33
I would guess your remotes won't flow enough oil. And the 3 hoses could be for pressure,return and power beyond. So you can tap directly into your hyd. system.
paul
07-26-2007 00:01:23
Not familiar with that brand backhoe. Most I see are 2 hoses, you detent or use a shock cord to hold the hyd lever open & the controls on the backhoe all work from the one flow of oil. You would need to set the backhoe for open center hydraulics which I believe your tractor has.
I don't understand the 3 hoses.....
--->Paul
