Tractor Talk Discussion Forum
IH V304 Intake Gasket
e
07-27-2007 11:04:36
This weekend I'm going to be putting the intake manifold back on my International 304 V-8. The intake gaskets are steel so I was wondering if I should be putting on any type of gasket sealant or should they just be installed dry?
As an FYI, I had the manifold off to look for a vacuum leak, but I think I may have found it elsewhere.
Hobo,NC
07-27-2007 15:10:00
 Re: IH V304 Intake Gasket in reply to e, 07-27-2007 11:04:36
You need a liquid sealer like permatex aviation gasket sealer/gasket maker or copper coat, around water ports use a good automotive silicon. not sure why but this sticks out in my mind, the valve cover bolts on the top side are drilled all the way threw into the intake port or the manifold bolts, use a sealer on the threads also. I have a rebuilt 304 if any ones is look"in, in a scout buy the engine git the scout free.
bill mar
07-27-2007 14:56:04
i think the amc 304 used the same style gasket,we used to put permatex gasket cement on the cooling system passages, all four corners if i remember right.
Hobo,NC
07-27-2007 15:12:49
 Re: IH V304 Intake Gasket in reply to bill mar, 07-27-2007 14:56:04
Yep the AMC is zackly the same set up.
kc4ee
07-28-2007 06:25:47
 Re: IH V304 Intake Gasket in reply to Hobo,NC, 07-27-2007 15:12:49
Nope, sorry the AMC 304 and the IH 304 are two
very different animals.
Hobo,NC
07-28-2007 16:34:22
 Re: IH V304 Intake Gasket in reply to kc4ee, 07-28-2007 06:25:47
I meant to agree that the intake gasket for the IHC has the same type of design as the AMC. sorry for the confusion
in-too-deep
07-27-2007 11:23:55
You might try posting this on the Classic Trucks forum on this site, or take a stroll over to oldihc(dot)org There's LOTS of truck guys there. Just make sure you come back here and visit s'more.
