Tractor Talk Discussion Forum
Re: 2 PTO shafts.
Bill Brox
07-29-2007 04:06:57
Ok, the tractor on the picture, is that a big tractor ?
I live in Norway, and I know a person who saw a tractor more than 20 years ago with 2 PTO shafts, I can not say what size it was, but maybe around 75 hp, maybe a little more.
And we started talking about what tractor it could be.
Bill
TGIN
07-29-2007 04:33:10
 Re: 2 PTO shafts. in reply to Bill Brox, 07-29-2007 04:06:57
Bill , I have a IH 706 thats about 40 yrs. old and about 75 hp with 2 shafts . One is for 540 rpm and the other for 1000 rpm . I dont think the 560 series that came before the 706 had the 1000 [ not sure ] but about all bigger IH tractors are able to have 2 shafts to date .
Allan In NE
07-29-2007 04:20:16
All IH large frame row crops "could have" the dual PTO installed.
At 75 horse and if it was an IH, it probably would have been a 706, 756, 766, 886 or the like.
Allan
Dan-IA
08-01-2007 19:13:31
 Re: 2 PTO shafts. in reply to Allan In NE, 07-29-2007 04:20:16
My 756 and 826 both have dual pto, 540 and 1000.
My 560 only has the 540.
Bill Brox
07-29-2007 04:23:41
Row Crop,,, is that with the 3 wheels only ? The tractor seen here in Norway was a regular 4 wheel tractor, but 2 wheel drive.
Bill
Allan In NE
07-29-2007 04:29:01
 Re: 2 PTO shafts. in reply to Bill Brox, 07-29-2007 04:23:41
Row crop means that the tread is adjustable for different row spacing. On both ends of the tractor.
Doesn't matter how many tires/wheels it has.
Allan
Leroy
07-29-2007 05:57:36
 Re: 2 PTO shafts. in reply to Allan In NE, 07-29-2007 04:29:01
Allan is used to thinking only wide front ends. A row crop is a cultivating type of tractor and it could be either a narrow (2 wheels side by side, 3-4" between tires at bottom) or a single front wheel or a wide adjustable front axle that you change the spacing of all 4 wheels to the row width you are wanting to cultivate. And up to 1959 all tractors had only a 540 RPM PTO shaft, in 1960 John Deere (Not sure about other makes) came out with an optional 1,000 RPM PTO shaft to transmit higher HP PTO shaft loads for larger PTO implements
Jon Hagen
07-29-2007 11:25:02
 Re: 2 PTO shafts. in reply to Leroy, 07-29-2007 05:57:36
Besides the millions of IH tractors with he factory dual 540/1000 shafts, dont forget the Mini Moline's that had basically the same 2 shaft 540/1000 pto. Another is Oliver which had the plug in 1 shaft 540/1000 pto where you could plug another shaft in the top hole and have an engine speed and rotation shaft in addition to your choice of a 540/1000 shaft below.
I have a good story about that Oliver engine speed pto option. I had an old engine driven 3 phase gen set that I picked out of a scrap yard with a bad engine that I wanted to use to power a grain dryer. I knew from the Oliver op manual that the engine speed pto could be fitted requiring only the little casting that the pto shaft plugs into to install. I removed the engine from the gen set and fitted it with a front bearing and pto stub shaft. With the generator coupled to the engine speed pto of the 1900 Oliver, it would run it very economically at only 1200 rpm.
The funny part was when I got to the Oliver dealer to buy the pto adapter casting. When I told the parts guy what I wanted he bristled up and demanded to know why I wanted that thing ???
When I explaned to him that I wanted to use it to run a generator at part throttle 1200 rpm and understood what it was, he calmed down. He said the reason he got upset was that another fellow had bought that exact same setup thinking that it was how you added a 1000 rpm pto to his tractor. It seemed the guy had bought a new forage chopper that needed a first for him 1000 pto shaft . The parts guy said that attaching that forage chopper 1000 rpm shaft to the Oliver engine speed pto which turned it in reverse at 2400 rpm blew the chopper knives right off that new chopper. lots of damage to a new machine.
