Tractor Talk Discussion Forum
PTO on my JD 4430
99pittsburgh
08-02-2007 22:37:01
I was bailing some hay last weekend and I noticed my bailer stopped turning. I stopped for a minute and it started turning again. The drive line going from the tractor to the bailer even stopped. Are the PTO cluches worn? If so how do you change them.
Dave H IA
08-03-2007 04:28:58
 Re: PTO on my JD 4430 in reply to Gordy from Iowa, 08-02-2007 22:37:01
Power shift or a quad range?? check cab mounts sometimes they break and throws off the linkage---check adjustment on linkage---power shift has a nut that can come loose on the short rod on the top of the transmission case ---clutches are a split job and different for power shift or quad range---got a book??? check pressures after the linkages
georgeky
08-02-2007 22:39:31
 Re: PTO on my JD 4430 in reply to 99pittsburgh, 08-02-2007 22:37:01
Does the tractor have plenty hydraulic oil in it? I have had mine on several tractors stop from time to time if low on Hy oil.
99pittsburgh
08-02-2007 22:41:05
 Re: PTO on my JD 4430 in reply to georgeky, 08-02-2007 22:39:31
The hydrolic fluid was ok.
buickanddeere
08-03-2007 04:44:25
 Re: PTO on my JD 4430 in reply to 99pittsburgh, 08-02-2007 22:41:05
Before ripping into the transmission, find out what is wrong. Put a pressure gauge on the pto clutch apply circuit. If the pto stops with the proper apply pressure then maybe the clutch is faulty. When was the last time the hydraulic oil, oil filter and screen were changed or serviced? Has your 4430 had the rear axle upgrade? What serial number? Do you have the operator's and service manuals?
