Tractor Talk Discussion Forum
Hay the way its done out west.
Walt Davies
08-03-2007 10:00:42
This is how we bale and ship our hay out here. There are 54 4X4X8 1 ton bales in this stack it is one truck load.
There are hundreds if not thousands of these all over the valley right now.
Walt
third party image
Clint Youse MO
08-03-2007 15:27:40
 Re: Hay the way its done out west. in reply to Walt Davies, 08-03-2007 10:00:42
yep get out west and they hook 2 48 foot trailers together instead of two 28 and a single 48 or 53 that makes 54 ton pretty easy but around here 4x4x8 bales will not weigh a ton usually around 1400
earlschieb
08-03-2007 15:11:51
third party image
I really don't think that would be a problem, I am not for certain how much these Michigan Trains can legally haul, but I would think 54 ton would be legal, most likely more than that.
MN Bob
08-03-2007 15:03:54
Hi Walt: You in the Columbia Basin? I worked a ranch not far from Trinidad for a few years growing up. Started at 12 on a D6 Cat. Still get back out there and yep, there is lots of the big squares there. Sure is a different place with the irrigation canals etc.
unioncreek
08-03-2007 10:58:05
They haul that many on a truck with a pup in our area all the time. We get up to 60 hay trucks a day hauling to the central basin area of Washington. It's then compressed and put in containers for shipment to Pacific rim countries.
Danno
08-03-2007 13:44:25
 Re: Hay the way its done out west. in reply to unioncreek, 08-03-2007 10:58:05
I'm pretty sure I saw a ford ranger driving down the gravel road last night that had about that much on it....third party imageI'm just kidding, of course, but I wouldn't put it past some of the locals to try.....
Kansas Cockshutt
08-03-2007 10:26:54
maybe 1000 - 1200 lbs a bale?
JCB
08-03-2007 10:18:34
I would like to see the truck that can haul 54 ton legally.
Walt Davies
08-03-2007 17:42:29
 Re: Hay the way its done out west. in reply to JCB, 08-03-2007 10:18:34
When I worked at Fort Ord, CA they hauled Tanks in and out all the time they way just over 60 ton. The biggest trailer I saw had 56 wheels on it. Double goose neck rear setup of wheels had hydraulic turning to get around corners.
Walt
