Tractor Talk Discussion Forum
blades
nate in mo
08-04-2007 20:35:42
I am looking for a cheap but, good quality blade for my 28 horsepower tractor any suggestions.Thanks
buickanddeere
08-05-2007 12:30:29
 Re: blades in reply to nate in mo, 08-04-2007 20:35:42
You need a blade rated for 75HP on a 25HP tractor.
Oldmax
08-05-2007 09:28:46
If you want good quality & cheap you might look around for a used one . They just don't come togeather. If you want good quality then you are going to have to open up your wallet & pay for it .
Bob Kerr
08-05-2007 07:48:54
I just destroyed a new Tractor supply blade when it hit a 3/4" tree root. I might make you a good deal on it, but it will need straightning and bracing. I am going to get a woods.
Mathias NY
08-05-2007 04:35:41
Places like Northern Tool and Tractor Supply are probably going to be your best spots for a new one. If you have a choice get one a little heavier duty than what your tractor is rated for, that way you won't ever break it. 28 engine HP will probably handle a 6' blade without problems. You would probably be happy with the one in the link.
gene bender
08-05-2007 02:58:56
So where have you looked as they are out there rated for horsepower and all.
Billpa
08-05-2007 02:50:24
There is no such thing as good quality and cheap!
Billpa
08-05-2007 02:50:17
Larry D.
08-05-2007 15:05:24
 Re: blades in reply to Billpa, 08-05-2007 02:50:17
HI.... I have just recently Posted about a rear Blade for a 35 HP tractor, And i have decided on a RB-72 6ft Blade by WOODS kinda pricey,$463.00 and that was the Cheapest I found!at a local Pwr eqpt Co.Larry
Billpa
08-06-2007 05:30:58
 Re: blades in reply to Larry D., 08-05-2007 15:05:24
Larry could you give more info like was the old one completly destroyed where you cant give measurements and if it is 6' wouldnt that be just the swing arm? if it is the whole blade shorten it and put short blades on the end let me know
Billpa
08-06-2007 05:15:41
Did you try a good spring shop?
