Tractor Talk Discussion Forum
HELP!!- What rims will fit a 40's wards wagon
Dave from MN
08-06-2007 13:11:18
Restoring a 40's era Mongomery Wards wagon. It has 5 hole rims. 2 are good , 1 is shot, and 1 is wrong rim. What other rims car, truck, or other would fit on it. She's all sanded and painted, got new knees and elbows, all it needs now is a set of matching rims and shes as good as she was when bought new. Original owner in his 90's is gonna love seeing it. It was his 1st rubber wheeled wagon, bought it new, then his brother traded the tires off it when he came back from "over there", apparently the wagon tires new were better than the tires that came on new cars at the time.
HENRY E NC
08-07-2007 10:24:29
 Re: HELP!!- What rims will fit a 40's wards wagon in reply to Dave from MN, 08-06-2007 13:11:18
I am in the process of restoring a 50's (I think) wagon made by Sears Roebuck and I found some trailer 5 bolt rims and tires for it at a junk trailer lot. Fiot perfect. Had some old wire spoke wheels but could not get them over the hub
BarryfromIA
08-07-2007 17:08:01
 Re: HELP!!- What rims will fit a 40's wards wagon in reply to HENRY E NC, 08-07-2007 10:24:29
Try to find some wheels from an Electric Wheel gear. Lots of them around, many got wrecked be cause they did not turn short.
p55
08-07-2007 04:55:11
If you are interested in new, I"d try Unverferth.They have a web site and have helped me with a lot of wheels over the years that I couldn"t locate.Prices are reasonable. Their site is unverferth.com p55
Paul from MI
08-07-2007 03:37:47
Usually what goes bad is the rims rust out, sometimes near the valve stem hole. I have repaired other "oddball" wheels by cutting off the old rim and cutting the center out of another good wheel. If you are careful the weld won't be all that noticeable. Carefully mark both wheels before you start cutting and use some scrap to hold everything in line and level. It won't work for an Indy car but it's fine for a wagon or plow, etc.
Paul
Don-Wi
08-06-2007 23:47:13
It may help to measure the hbolt circle on it, then we may know of some rims of that pattern if we aren't familiar with what they had way back when.
here's the link ot Miller tire. They havce several different 5 bolt sizes, and they show how to measure a 5-bolt rim in the FAQ's section.
Donovan from Wisconsin
Leroy
08-08-2007 05:12:13
 Re: HELP!!- What rims will fit a 40's wards wagon in reply to Don-Wi, 08-06-2007 23:47:13
5 1/2" bolt circle, 4" center hole. Same as standard 5 lug on any inplement.
Don-Wi
08-08-2007 23:53:31
 Re: HELP!!- What rims will fit a 40's wards wagon in reply to Leroy, 08-08-2007 05:12:13
IN that case there's a whole bunch that will fit. Rims off any ford 1/2 ton truck w/ a 5 bolt rim, Older Jeeps, I think even Dodge used that pattern. Trouble with ford rims is the center pilot bore is small, so it's have to be cut out.
I found all the standard 5 on 5 1/2" rims I needed at a boneyard. They had a large pile of tires of all sorts, just found 4 that were the 5 bolt 15" rim. Found 2 or 3 more at the local metal scrap yard. Nothing wrong other then the ugly puke green paint on one...
RustyFarmall
08-06-2007 14:41:49
I think that bolt pattern is the same as what was used for the pre-'73 Ford 1/2 ton trucks, but the truck wheels will probably not look quite right. Most of the wagons from that era used the same wheels with the same bolt pattern, and there may even be some modern implements that still use that same wheel.
