Tractor Talk Discussion Forum
Owatonna 1700 skidloader
20mmDale
08-08-2007 11:06:38
My 1970"s Owatonna 1700 skidloader will not tilt it"s bucket or lift. Do you think the hydraulic filter is clogged or ?? It moves forward and back fine. Thanks in advance for your help.
20mmDale
08-10-2007 19:16:33
 Re: Owatonna 1700 skidloader in reply to 20mmDale, 08-08-2007 11:06:38
Thanks for the help guys. I replaced the filter and found #40 chain links and pieces. Deducted that it must be from an earlier breakdown of steering components. They must not have cleaned all the parts out of the resevoir... Took the hydraulic pump off ( gear driven ) and found the problem. Pump teeth and housing destroyed from injestion of #40 chain pins. Looking for a new pump, Cessna 24308 RAJ, 170-21-707. Thanks again ! Dale
bradk
08-10-2007 18:22:28
Call Northland Farm Systems.Ask for Paul.VERY helpful fella.507-451-3131
~brad
msb
08-08-2007 14:09:37
First place to check is the flex coupling to the hydraulic pump. Sometimes the rubber coupling goes bad. Check the filter next.
