Tractor Talk Discussion Forum
help identify this loader 460U
Gary in Mozarks
08-12-2007 06:43:06
third party image
I posted some pics on help identify Can anyone help me identify this loader? Its pretty heavy duty Slow detachable. On the rear casting where it attaches to the rear axle (and on several other castings) it has a cating number WW and 3 or 4 numbers
J.C. IN AZ.
08-12-2007 08:07:00
 Re: help identify this loader 460U in reply to Gary in Mozarks, 08-12-2007 06:43:06
IHC 460U's came from the Factory with IHC Mfg. Loaders for Farm use which had a Tube type Frame and Lifting Arms. Can't remember the Model #'S . 460U Industrial came with a heavy Frame and Loader Arms of Rectangular Steel in a wishbone design. Industrials were painted "Federal Highway Yellow"
IaGary
08-12-2007 07:18:34
Can you get us a picture of the whole loader?
Might be easier to identify that way,rather then pictures of the numbers.
Gary
Gary in Mozarks
08-12-2007 08:14:12
 Re: help identify this loader 460U in reply to IaGary, 08-12-2007 07:18:34
third party image
I put 4 pictures in the help identify column. The loader has a large diameter round pipe across the front of the radiator. Judging by the bracketry, its not factory looks like someone modified some other brackets to make it fit the 460U I thought maybe the WWnumbers might be a giveaway. Thanks for your consideration. Gary
J.C. IN AZ.
08-12-2007 10:52:54
 Re: help identify this loader 460U in reply to Gary in Mozarks, 08-12-2007 08:14:12
Looks like a series 2000 Loader for a row crop IHC Tractor and not for a Utility. Has been modified I would say.
IaGary
08-12-2007 10:39:23
From what I see it may be a Koyker loader.
But the loader is for a rowcrop tractor not a utility.Someone modified it to fit a utility.
With it set up the way it is how do you get on the tractor?
Gary
Gary in Mozarks
08-12-2007 13:29:27
 Re: help identify this loader 460U in reply to IaGary, 08-12-2007 10:39:23
Havn't tried to get it off the tractor yet Thats the way I bought it. Looks like you pull two pins on the bottom and drop the central part down and back the tractor out of the rear couplings? Then I don;t know how you would get the front wheels through the maze.
