Tractor Talk Discussion Forum
Leaking injection pump
BrianRM
08-13-2007 09:54:21
third party image
This is a pump on a 1975 Case 1370 with about 6250 hours. I just got it and it runs real good but there is a slight leak from the manual pump area. You can see the flat ridges on the lower part and it looks threaded but can I tighten this a bit or will I do more harm than good.
NC Wayne
08-13-2007 17:34:07
 Re: Leaking injection pump in reply to BrianRM, 08-13-2007 09:54:21
Got to agree with Doug. CAT uses the same type pump on some of their equipment and the best thing for one that's leaking is replacement.
Doug in Amarillo
08-13-2007 16:49:08
I worked for Case many yearsand when the manual pump starts leaking all you can do is replace it.The seals inside the pump are worn out.They are still available thru Cas e and they are not very expensive,so save yourself a headache and just replace it.
c hess
08-13-2007 15:59:10
you can hand tighten.
BrianRM
08-13-2007 12:28:38
 Re: Leaking injection pump (picture here) in reply to BrianRM, 08-13-2007 09:54:21
third party image
Here is the picture...sorry. The manual pump is in the center. Do you think I can tighten this down a bit? Thanks
