Tractor Talk Discussion Forum
2003 Yamaha Blaster
Frankie
08-13-2007 17:55:42
200cc 2 stroke. Running until died from what sounded of starving for gas. Will not run now and still sounds like its starving for gas when plug is wet. Will run for 1 sec but dies when given gas. Cleaned carb. Spark, Gas, compression? What else could be wrong with it? My expert says maybe reeds. Im thinking rebuild carb. Any suggestions? I havent had this for more than 2 months. Help please.
rrlund
08-14-2007 13:46:44
 Re: 2003 Yamaha Blaster in reply to Frankie, 08-13-2007 17:55:42
We've got three of those around here. Sounds just like reeds to me.
shawnspeed3
08-14-2007 04:59:57
Reed or crank seal. Either way you are loosing pumping efficency in the crank case. Reeds are an easy fix and 40-60 bucks ....crank seal is basicly a total overahual , as you may as well do the crank rebuild,and ring it at the same time, as you have to split the case to do it properly. Shawn
ChrisLSD
08-13-2007 20:07:59
I have a 1988 - everything original - ervything great -
sometimes if it sets for a few months without a ride it is very hard ot start - basically crappy gas i think - I am still running the original spark plug -
when it is being difficult i have hooked it to the pickup and given it a pull start - sure helps the kick starting leg and it usualy starts rather quickly -
Frankie
08-13-2007 20:39:58
 Re: 2003 Yamaha Blaster in reply to ChrisLSD, 08-13-2007 20:07:59
Its been used at least four times each week and last time I drove it, the motor just died. I tryed pull starting by pulling it with my aunts Blaster but it will not fire. Like my expert said; reeds or rings and carb rebuild?
