Tractor Talk Discussion Forum
removing surface rust from a cab
jacksonduper236
08-13-2007 20:38:14
I just purchased a year a round cab for an IH 56 series. I thas some surface rust on the cab. What is the best and easiest way to remove the surface rust.
apz*jr
08-14-2007 16:46:58
 Re: removing surface rust from a cab in reply to jacksonduper236, 08-13-2007 20:38:14
Just wire brush it with a drill or angle grinder, and then use Purple Power, which you can get at Advance Auto Parts, this is only if you want to paint it.
souNdguy
08-14-2007 07:23:56
Naval jelly will it it clean.. but then ya got to protect the metal.. I like the rust converter / primer idea.. especially if it 'seals..
Soundguy
Don-Wi
08-13-2007 23:25:26
The absolute easiest way to take care of surace rust is to buy a rust converting primer.
I got mine from Eastwood, I just got a spray bomb because I only needed it for my engine and hydra-power on my 1600. Was plenty in the can, and so far so good. I got the heat resistant stuff but for a cab you could go with the other stuff.
Donovan from Wisconsin
