Tractor Talk Discussion Forum
9nhydralic pump removal
C.bailey
08-17-2007 20:45:28
How on earth is the hyd. pump fastened to the lower cover? There are no outer bolts from the cover in, and no apparent ones on the inside of the tractor midsection from the pump to the cover. If this is a one piece deal then how would the whole assembely be removed? Any advice would be greatly appreciated!!!!! !
Ken L.
08-18-2007 17:09:34
 Re: 9nhydralic pump removal in reply to C.bailey, 08-17-2007 20:45:28
Drain the oil, pull out the PTO shaft, it goes through the pump, then just unbolt the cover. I would put a floor jack under it before I removed the last couple bolts. It should then come out as you lower the jack.
Super 55
08-17-2007 22:25:02
C. I think you would get a faster response if you go to the 9N board, on this website.
