Tractor Talk Discussion Forum
Kabota Diesel Governor
DarrylMueller
08-18-2007 14:43:49
I am trying to get information on kabota V-1900 Governor, 1994 year. I have sent the pump out and it's OK. The motor is on a generator that need is to run at 1800 RPM. The engine pulls down. I have backed out the fuel screw with no increase in power, no smoke. I don't think the govenor is working. Thanks for any help.
Walt Davies
08-18-2007 20:59:47
 Re: Kabota Diesel Governor in reply to DarrylMueller, 08-18-2007 14:43:49
If the governor wasn't working you couldn't get it stay at 1800 with no load. you may just be overloading the system or the generator my have a problem.
Walt
DarrylMueller
08-19-2007 12:35:10
 Re: Kabota Diesel Governor in reply to Walt Davies, 08-18-2007 20:59:47
Kobota rebuilt the governor, after that the engine ran away and scartered the aultinator. Kobuta rebuilt the governor because the engine speed sometime was fine then the next time it started it the speed changed. I think that they did not do a good job on the rebuild and the problem is still in the governor. I set the speed at 1800 as power is applied the engine pulls down no smoke it needs more fuel and the governor is not moving the rack against the fuel screw.
