Tractor Talk Discussion Forum
Trailer Hitch
37 chief
08-20-2007 11:25:09
I have a wood chipper the hitch is only a 3/4 in. bolt, and nut to attach it to my turck receiver. Is this legal? There is a lot of weight up front on the chipper. There is a Ford V 8, at the front end and the weight of the chipper. If it is legal I will probably just leave it. It just jerks a lot when I pull it a round. I just got this unit, and hoping to make a little extra money when the mowing and discing are through for the year, which is just about now. Stan
doogdoog
08-21-2007 02:33:32
 Re: Trailer Hitch in reply to 37 chief, 08-20-2007 11:25:09
Aloha, Is it possible to post a picture of the hitch?? The hitch that you are describing doesn"t seem right.
Mahalo,
doogdoog
john *.?-!.* cub owner
08-20-2007 19:52:32
 Re: Trailer Hitch in reply to Jerry/MT, 08-20-2007 11:25:09
Gary, read the weight restrictions stamped on your bumper. If you are exceeding them you are leaving yourself wide open for a lawsuit, if you are ever in an accident, whether it involves failure of the hitch or not.
paul
08-20-2007 18:28:51
Do you have 2 safety chains? Last time I read the rules it said you need a pin with a keeper on it & 2 saftey chains.
Your bolt with nut meets the basic item, but in a lawsuit it would be a lot easier to say _this hitch pin_ that was sold to me as such broke, so the accident is not totally my fault, but the fault of the _hitch pin_ manufaturer..... Otherwise you gotta prove your bolt was strong enough, etc. etc.
--->Paul
Oldmax
08-20-2007 17:49:10
If you are pulling with a bumper hitch that is your problem I would not pull anything with a bumper hitch . Get you a hitch that is at least Cat 4 then you can pull without worry . Some of the jerking is in the bumper .
Gary from Muleshoe
08-20-2007 18:41:21
 Re: Trailer Hitch in reply to Oldmax, 08-20-2007 17:49:10
OldMax I disagree with you on that. I pull a 16' car hauler all the time with just a bumper hitch and have never had a problem. Have not once had to tighten the bolts on the bumper or anything. I will agree that some of the older trucks did have a problem with the bumpers coming loose. I have not on my 99 F150. Safety wise I believe my bumper is just as stout as a reciever hitch.
Walt Davies
08-20-2007 14:06:31
Make sure that your hitch and Pin are all the same size that will eliminate the jerking. The pin is a better stronger way to tow your chipper that's why they use it. Any farm supply will have the correct pin for you. $5 to $10 bucks. Walt
Don-Wi
08-20-2007 12:30:36
I think I'd use a hitch pin and not a bolt, but I see noreason for it to be illegal. Puttuing a ball on would definately take up a lot of the jerking, or you could buy a shock-absorbing receiver hitch like I did for my truck. Cost was only about $45 and I use it for pulling all the farm implements.
Donovan from Wisconsin
Gary from Muleshoe
08-20-2007 11:28:15
I am not if it is legal or not, but it wouldn't cost that much to convert it to at least a 2" ball. It will take all the jerking away and it will trail alot better down the hi-way.
Flat Ulant
08-20-2007 11:27:58
That would be used with a double plate bumper and approved hitch pin.
