Yanmar 155D hydraulics
Stan
11-08-1999 18:05:47
I tapped into the hydraulics on my YM155D to run a loader. Neither the loader or 3 pt lift will work unless both control valves are activated and there is a resistance load on the lift. I guess I'm trying to run two hydraulic circuits on a single circuit system. Any suggestions on how I can run each independently?
GEO
11-09-1999 18:02:29
 Re: Yanmar 155D hydraulics in reply to Stan, 11-08-1999 18:05:47
If you have put a tee on the line, remove the tee and take the line from the pump to the loader valve then back to the tractor to completer the circuit. If the loader valve you have has a power beyond port use it to feed the rear lift and use another hose on the return side of the loader valve to return to the reservoir.
john vukman
10-17-2004 16:33:39
 Re: Re: Yanmar 155D hydraulics in reply to GEO, 11-09-1999 18:02:29
I have a question about the pump i have a 155d and the pump housing cracked I have had no luck finding a housing or the pump does anyone have any suggestions. It is a kyb pump that is on it now can I use a different make if so what is the make and part #? Thanks
