Tractor Talk Discussion Forum
466
smdv806
08-21-2007 19:23:33
I was wondering if the Navistar 466s with allison transmissions on them have the same bell housing bolt pattern as farmall six cylinders?
ejr-IA.
08-22-2007 09:51:36
 Re: 466 in reply to smdv806, 08-21-2007 19:23:33
Yes ,if you want to put in a tractor you will have to get the tractor motor front and rear mounting plates,oil pan,pickup tube,flywheel,exhaust manifold and maybe a pilot bearing for the crank.
smdv806
08-22-2007 13:52:39
 Re: 466 in reply to ejr-IA., 08-22-2007 09:51:36
I have a 460. Can I use some of the parts off of my 301 gas on the 466? flywheel etc...?
ejr-IA.
08-22-2007 14:54:59
 Re: 466 in reply to smdv806, 08-22-2007 13:52:39
That combo I think won't work in a 460 because the 460 has the small clutch houseing not saying it can't be done .I know that they have used 560's because they have the larger clutch houseing.
Allan In NE
08-21-2007 19:30:33
Pretty sure that they are the same darned engine/block. Difference is in the crank and cylinder kits.
Allan
smdv806
08-21-2007 19:27:33
not a navistar, slightly older, IH
