Tractor Talk Discussion Forum
hey allan, or other tranny expert
D17 man
08-22-2007 17:47:59
i just bought a 83 chevy k10 and need help identifying what kind of tranny it has. i was told by the previous owner that its a t-350 with a aftermarket overdrive but my friend looked at it and thinks its a 700R4. u got any tips on figureing what it has?
thanks
Allan In NE
08-22-2007 19:02:01
 Re: hey allan, or other tranny expert in reply to D17 man, 08-22-2007 17:47:59
The '82 thru the '86s were the black years for GMs light truck automatic transmissions. They got better in '87 thru '90, finally got 'em figured out in '91 and then went totally electic with that design in '93.
1983 4X4s with automatics came from the factory with either the 700 over drive or a straight 400 three speed. 2 wheel drive automatics came with the 350C or 200C, which were "lockers" (torque converter lock up).
Over the years tho, an awfully lot of those 700s got swapped out for the 350s that folks were used to in years past. Fuel mileage took a huge hit, but they were more reliable than those first overdrives.
Like the other guys say, retanglar pan is the 700, square pan with the corner cut off is a 350, and the 400 had a kidney shaped pan.
Allan
rick in sc
08-22-2007 18:28:31
D17 Man, 700-R4: 4sp,roughly rectangular pan, DOES NOT have a vacuum modulator. 350: 3sp, pan roughly square pan with a "clipped" rt. rear corner, HAS a vacuum modulator. Rick
bradk
08-22-2007 18:21:12
Easy enough.The 700R-4 has four forward positions at the shifter.A 350 has three.
Aftermarket over-drive??? Maybe he meant automatic over-drive.
