Tractor Talk Discussion Forum
John deere B
wenning
08-22-2007 20:04:49
Does anybody know the weight of oil and what oil filter to use in my 1948 JD B Also if You happen know what sickle bar mower will fitt it
MLD
08-23-2007 06:02:25
 Re: John deere B in reply to wenning, 08-22-2007 20:04:49
Regular plain old 30w oil is what I always use, seems harder to find now then in years past.
James in Al
08-23-2007 05:12:54
The JD operators manual calls for straight 30 weight oil. I switched from the recommended 30 weight to 10W-40 in a H Farmall once and it started smoking and using oil. Switched back to 30 and it stopped.
Wisconsin Cowman
08-22-2007 20:26:25
When worked on my neighbors B I used fram part number C139PL and 15W40 for oil. For a mower the best match would be a number 5 plenty of them out there and you can find them cheap and in good working condition.
RobMD
08-22-2007 20:17:03
A John Deere number 5 mower with the brackets to fit the B works well.
Andy Motteberg
08-22-2007 20:08:32
I think the oil should be 10w40 or any heavy duty all season engine oil. I cannot remember the oil filter number, but you can look it up on www.fram.com Fram filters are good. Or you can go to a parts store and they will look it up for you.
Andy.
