Tractor Talk Discussion Forum
Power steering problem
alan bane
08-23-2007 08:01:23
I have an 860 Ford tractor with power steering and it works well at high RPM'S but doesn't work good at an idle. It is not low on fluid.When I started using it this morning, the power steering worked good idleing What could be the problem ?
sparepartsTN
08-24-2007 15:35:14
 Re: Power steering problem in reply to alan bane, 08-23-2007 08:01:23
My tractor didn"t have a filter either, but with pictures in the master parts catalog and the service manual, I made the missing parts with heavy galv. wire and flat washers.
Jon Hagen
08-23-2007 18:38:06
Are you using automatic transmission fluid in the power steering ? That used to be the standard steering fluid, but now most everything uses a fluid specifically formulated for power steering and it does a better job than ATF. Modern power steering fluid is quite a bit more viscous than ATF and often helps compensate for worn pumps. Might be worth a try before buying new iron.
alan bane
08-23-2007 19:26:59
 Re: Power steering problem in reply to Jon Hagen, 08-23-2007 18:38:06
I had new gaskets and seals put in the steering column last year and when I put new fluid in it ,I used Chevron ATF. It worked well until today.I'll try the power steering fluid. Thanks
Mike (WA)
08-23-2007 08:19:40
Any hydraulic system that works OK cold, but then tapers off when warmed up, is usually a sign of a worn pump (oil is thicker when cold, but when it warms up and thins out, leaks by the worn parts).
Bob
08-23-2007 08:03:52
The pump MAY be worn out, or the filter may be clogged (located inside the pump housing, IIRC).
A change of oil couldn't hurt, either.
alan bane
08-23-2007 11:14:18
 Re: Power steering problem in reply to Bob, 08-23-2007 08:03:52
It never had a filter in it when I bought it. I tried to buy an assembly to hold the fiter in and you can't get them anymore.You can buy the filters at Ford .I sure would like to have a filter in there.
Mike M
08-23-2007 12:01:46
 Re: Power steering problem in reply to alan bane, 08-23-2007 11:14:18
No filter in there well you may of just found the problem ? That could of worn your pump out. Good news is I think there are plenty of aftermarket people selling those pumps maybe even new and they should come with a filter.
