Tractor Talk Discussion Forum
What have I done???? (this time)
Lanse
08-24-2007 13:36:14
Well, my New Holland TZ25 and I were out tilling away at the fall garden I'm gonna start, when all of a sudden the engine really slowed down, then stopped. flicked off PTO,, started right up, flicked it on, it died. What do you think could be wrong with it? Runs fine till I turn on the PTO. Thanks alot!!
TomH in PA
08-25-2007 06:21:26
 Re: What have I done???? (this time) in reply to Lanse, 08-24-2007 13:36:14
Doesn't the tiller have a slip clutch or shear bolt? Maybe your tractor doesn't have enough HP to slip/shear it, but make sure it will protect the machine(s) just in case. Slip clutches tend to get stuck if you don't back off the tension and clean the surfaces once a year.
Davis In SC
08-24-2007 21:53:36
Lanse, maybe you need to pull the head off of the tractor. That seems to be the fix for mowers... Just kidding, please do not pull the head..
Lanse
08-24-2007 17:08:57
Safty switches have'nt worked since I got the thing, well, anyway, There was a rock jammed up in there. I feel REAL stupid.
Badly Bent
08-25-2007 04:33:14
 Re: What have I done???? (this time) in reply to Lanse, 08-24-2007 17:08:57
Now you know what to look for if it ever happens again. My mother always said that experience was a dear teacher. You remember things you learn the hard way.
Dairy farmer in WI
08-24-2007 19:21:56
it's alright we all have our stupid momnets. like the calssical"where'd i put that?!" when what your looking for is in your had or right in front of you. i do it all the time! have a good weekend!
DF in WI
iowa_tire_guy
08-24-2007 20:43:06
 Re: What have I done???? (this time) in reply to Dairy farmer in WI, 08-24-2007 19:21:56
Have you really been looking for something that was in your hand? I thought maybe I was the only one to do that. Or was this a trick to get someone to confess?
RobMD
08-24-2007 17:16:35
well, stop feeling that way and live and learn.
Lanse
08-24-2007 17:36:55
 Re: What have I done???? (this time) in reply to RobMD, 08-24-2007 17:16:35
Thanks!!
old
08-24-2007 15:08:39
Could be a safety switch going bad also. Not sure if it has a PTO safety or not but I know some of the newer stuff have them and if you stand up with the PTO engaged they can be set up to kill the engine
higgins
08-24-2007 13:58:05
Check to see if those 8th grade textbooks are pluggin' it up. They're way heavier than the ones I had in the 60's....
Gerald J.
08-24-2007 13:53:15
Wrapped up a piece of clothesline or fence wire in the tiller.
Gerald J.
CWL
08-24-2007 13:53:11
Sounds like you plugged up the tiller. Did you pick up some wire or something?? Another thing to check is that the gear box has plenty of grease and is not binding.
