Tractor Talk Discussion Forum
allis-chalmers 190 xt series 3
doug wettstein
08-24-2007 19:42:27
i just purchased a 190 xt series 3 allis chalmers, 1969
i am having trouble with the hydraulic fluid
leaking back into the transmission fluid.
there was a plugged vent tube on the transmission
which i unplugged. then i took the tractor for a 2 mile drive down the road and rechecked the fluid levels, with the transmission fluid being slightly higher. i could not notice a level differance in the hyd. reservoir, also why would the fluid only transfer in one direction instead of the direction? transmission to hyd.
Joe(TX)
08-25-2007 16:20:03
 Re: allis-chalmers 190 xt series 3 in reply to doug wettstein, 08-24-2007 19:42:27
There are 2 seperate reservoirs. The use the same fluid for the transmission and the transmission.
doug wettstein
08-25-2007 10:42:24
there is 2 seperate reservoirs with 2 differnt weight fluids in each causing a hyd. performance issue, using too heavy of a weight fluid.
it would be great if i could run a hytran fluid, but do i need a seal kit or something for that?
doug wettstein
08-25-2007 10:42:17
rrlund
08-25-2007 07:21:47
Did they have two seperate reservoirs? I might be wrong,but I thought they just used hytran (hydraulic/transmission) fluid in the whole system and that it was all one.
