Tractor Talk Discussion Forum
MF-65 rear wheel
Mark Watkins Ky
08-26-2007 17:49:03
I need a little help once again. My MF-65 is in need of a rear wheel. The area around the valve stem is badly rusted out. This web site list two different wheel sizes. They are 10x28 and 11x28 wheel sizes. The tractor has a 14.9x28 inch tire size. Which wheel do I need??? Thanks...
Mark Watkins Ky.
08-27-2007 17:48:35
 Re: MF-65 rear wheel in reply to Mark Watkins Ky., 08-26-2007 17:49:03
The tire is still on the rim. It seems to measure about 12 to 13 inches. It also is a spin out/in type with 4 rails. Thanks for your replys.
JMS/MN
08-27-2007 08:01:42
They are both too small. The 14.9 tire fits best on a 13 inch wide rim, but is ok on a 12 inch. What you have can be fixed with some new steel or a piece cut from a donor rim. Check back a few days in these pages for a similar post and answers.
Bob N.Y.
08-27-2007 06:42:30
Do you have the tire off the rim? If so, measure across the inside of the rim where the tire seats to find the rim width. If the tire is still on, you could approximate the width from the outside.
