Tractor Talk Discussion Forum
Touch Control Fluid?
48C-MAN
08-28-2007 15:02:19
What is a good replacement for this and how much do I need to fill a Farmall C Touch Control unit?
mark
08-29-2007 06:11:49
 Re: Touch Control Fluid? in reply to 48C-MAN, 08-28-2007 15:02:19
Fill it up with Dexron ATF..works excellent.
georgeky
08-28-2007 19:06:10
It holds just a tad more than 4 quarts. Hy Tran or AW-32 hydraulic oil will work in it. Non detergent motor oil also works fine in them. I use 30 weight non detergent oil in mine to slow the leaks a bit. I have used it for years with no problems. In extreme cold the 30 weight is a bit heavy and hydraulic oil or 10 weight non detergent should be used.
Red Dave
08-28-2007 16:53:24
Today it is called Case/IH Hytran Plus. I don't know how much a C needs.
