Tractor Talk Discussion Forum
Oil Pressure guage
RFox
08-28-2007 19:41:48
Any advice on where best to buy a mechanical oil pressure guage for a JD 4020? I've heard to only use metal tubing. My tractor has a turbo, so one of the oil ports is being used. But it looks like there are two? Thanks!
Jerry in KY
08-28-2007 20:06:11
 Re: Oil Pressure guage in reply to RFox, 08-28-2007 19:41:48
You can buy a guage at any parts store. Get the copper tubing kit to go with it too. I plumb a 3 way fitting at the block where your oil light sending unit screws in the motor. You can put the oil line on one side and your sending unit for the light on the other side of the T pipe fiting. Hope this helps. Jerry
Bob
08-29-2007 07:21:18
 Re: Oil Pressure guage in reply to Jerry in KY, 08-28-2007 20:06:11
Use an ELECTRIC gauge. It's NOT uncommon for the copper lines to crack and break, with potentially di$a$$terou$ results.
soundguy
08-29-2007 11:15:35
 Re: Oil Pressure guage in reply to Bob, 08-29-2007 07:21:18
And i especially don't like the stiff vinyl (??) capilary lines for the same reason..
soundguy
