Tractor Talk Discussion Forum
new holland hay bine help
havvey
08-29-2007 06:28:33
I am looking at a 474 or 469 (unsure of modle number at this time) it is 7 foot and works what is a rough price? go with average condition. what are there week points. Last the rolls hang up occasionally and hay wraps around them so i am told what cause's this? Are parts still available? thanks all
JM in Merit
08-29-2007 11:08:37
 Re: new holland hay bine help in reply to havvey, 08-29-2007 06:28:33
I had a 478 that was 7 foot. It was pretty good just slow. Had to have the wobble unit rebuilt one time, other than that just normal stuff.
Other than that is was good. Traded it off because of fire ants mounds plugging it and bought a disc cutter.
Tom in MI
08-29-2007 09:55:07
I have a NH 469 haybine. It is a 9 foot wide model. Yours should be a 467. In regards to the rolls hanging up, you need to time them in together. The ribs on the rolls must not touch each other. The lower roll (on the drive side) has an adjustment flange on the end of it where you can advance or retard the position of the roll so that it meshes with the upper one properly. This isn't hard to do. Also the drive chains should be kept taught so there is no back-lash. Around here, a good machine will go for about $1,500.
Dick
08-29-2007 09:32:08
Hey Walt,,
I have a NH model 77 baler and I'm finding it harder and harder to find parts for it. Where do you find parts for your model 78? I don't need anything right now, but most likely in the future. Any suggestions?
Thanks,
Dick
Walt Davies
08-29-2007 12:27:52
 Re: new holland hay bine help in reply to Dick, 08-29-2007 09:32:08
Dick I got all mine at the local dealer they told me that they could get most parts for it. Even had what I wanted right there. The 77 might be older than mine also you local dealer might just be two lazy to stock or get parts for you.
Walt
PS when i rebuilt the pickup I just went down and bought some black iron pipe and some washers and and made my own parts for it. cost a whole lot less.
Dick
08-30-2007 13:14:37
 Re: new holland hay bine help in reply to Walt Davies, 08-29-2007 12:27:52
Thanks Walt,
I think you're right about lazy parts dept. employees. A good parts person is a valuable asset to a parts store. It's easy and cheap to hire young people that don't know what New Holland is,, they think that's a place in Europe. This is the problem here, a good parts salesman that will try to help you. You're also right about using the steel pipe instead of NH parts that would cost a fortune.. Good advice Walt..
Thanks
Walt Davies
08-29-2007 07:29:34
I have a NH 78 and parts are still available for it. I had to rebuild the whole pickup system as it was completely worn out. Check all parts for ware also the feed into the bale chamber bearings will be shot but can be replaced.
these things can look good but be worn beyond what they are worth to fix. Check it ocer real good from front to back and all bearings and chains and other moving parts. check knotters for excesive wear.
Walt
