Tractor Talk Discussion Forum
Re: pulling a tractor question
buickanddeere
08-31-2007 06:46:19
I have to ask if you are being serious or if you have zero experience on or around a tractor? b.t.y. The all capitals is very rude.
1965LONEWOLF
08-31-2007 07:08:31
 Re: pulling a tractor question in reply to buickanddeere, 08-31-2007 06:46:19
WHAT ARE YOU A JOKER ? I VE BEEN AROUND TRUCK PULLING FOR 20 YEARS BUT TRACTORS ARE DIFFRENT , DON'T KNOW THE HORSEPOWER BUT I AM GUESSING AROUND 75 - 90 HP , FARMALL M TRACTOR , ITS BECAUSE I PULL AGAINEST A OLIVER THAT PULLS IN 1 ST GEAR AND KEEPS IT AT 1000 RPM AND CRAWLS DOWN THE TRACK . I AM IN THIRD AND IF I TRY TO GIVE IT TO MUCH GAS IT FEELS LIKE THE TIRES WANT TO SLIP A LITTLE - THATS WHY I ASKING ABOUT HTE RPM QUESTION
John (MO)
08-31-2007 10:40:13
 Re: pulling a tractor question in reply to 1965LONEWOLF, 08-31-2007 07:08:31
Most rules limit you to a small % of RPMS over factory. So I doubt you are going to be able to run the high RPM numbers. Besides that isn`t typically where old tractor engines make their power at. If you are running in 3rd gear with a Farmall M, I have to wonder if you do not have a speed limit. I think you need to take a lesson from that guy that is beating you. He obviously knows where the power curve of his engine is and he is using that knowledge to blow you off the track. IT AIN`T ALL ABOUT SPEED DUDE. IT`S ABOUT HOOKING THE HORSEPOWER TO THE TRACK. ANY HORSEPOWER THAT AIN`T HOOKED TO THE TRACK IS USELESS.
