Tractor Talk Discussion Forum
metal roofing
jaybird-oh
09-02-2007 18:48:07
I'm thinking about reroofing some sheds with metal. The sheds have 1/2" plywood sheeting with 90 lb.roll roofing. Will it be ok to strip the old roll roofing off and install the metal right over the plywood sheeting? I've always used asphalt roofing and know nothing about metal roofing.Thanks for any advice. Jay
in-too-deep
09-04-2007 12:24:53
 Re: metal roofing in reply to jaybird-oh, 09-02-2007 18:48:07
I agree with the rest. 2x4 purlin boards laid flat at 2 ft. O.C. Make sure you lay the sheets in the right direction according to prevailing winds. You don't want the edges of the overlap facing into the wind. Oh, and drive the screws on the ridges of the metal, not in the valleys.
big N
09-03-2007 20:07:26
put down 2x4 and use screws or else in a strong wind it rip the metal right off
young gun
09-03-2007 14:44:36
make sure u put 2x4's down first and use screws youll be fine
Dave Sherburne NY
09-03-2007 08:19:56
Check out this website FABRAL
fixerupper
09-03-2007 06:45:10
A couple of years ago I watched the wind peel off metal roofing that had been nailed through the shingles and into the sheeting. It was a wicked sight to see those sheets curl up and fly away like lethal weapons. Now, I know they were nailed and not screwed, so screws might have held, but if the sheeting is beginning to rot the screws won't hold either. If you put down 2x4's first the chances of losing the metal are much less, and the 2X4's do help make a crooked roof look flatter. Removing the old roofing might be necessary if there are three or four old layers and the roof isn't strong enough to hold the extra weight of another layer. The old shingles do act as an insulator that will keep the new steel from dripping condensation if the sheeting is spaced apart for wooden shingles.Jim
alan bane
09-03-2007 06:05:48
I was told about a month ago not to put metal roofing over old shingles , that it would cause the shingles to crystallize due to the intense heat. Is that true or have you ever heard someone say that?
El Toro
09-03-2007 04:37:56
I helped my late father-in-law to put a metal roof
over his asphalt roof that had several layers in 1963 and that roof is still on that house. Hal
Tim, Ohio
09-03-2007 03:31:22
I also want to add that you do not want
to use treated lumber for runners unless
you put a barrier between the tin and
the treated wood. The metal will react
with the treatment (copper sulfate) ane
will prematurely corrode your tin.
I second the 2 x 4 runners. You need the
air space to let the tin breath. Even though the
tin will sit 1 1/2 " higher on the roof, there
is a camp at the rake ends which will cover it and extend down over the edge.
Tim, Ohio
paul
09-02-2007 20:45:42
I'd leave the tar on if in good shape.
Might want to ask, _some_ metal reacts badly & would need craft paper over the tar. Usually not a problem...
Wood is thin, hope it's good shape, use screws not nails.
A more common way to do this is put 2x4s flat across your roof every 2 feet, screw them well into the rafters, then put the tin onto the top of the 2x4s. Don't bother any at all with whatever is on the old roof, just strip over it.
NEsota
09-02-2007 19:03:22
If the surface of the 90 pound roofing presents a smooth surface that will not distort the tin, then you might as well leave it and put the tin over it.
Bob
09-02-2007 18:57:37
I would think the 1/2" plywood MAY be a bit thin for the roofing screws to get a secure grip to avoid having the tin tear off easily in a wind, but maybe not???
RobMD
09-02-2007 21:53:59
 Re: metal roofing in reply to Bob, 09-02-2007 18:57:37
You have to have a full 1 1/2 inches of metal roofing nail into 2x4 runners.
A 1 1/2 inch roofing nail into 1/2 inch plywood is like DUCT TAPING the metal to the roof.
He needs to have the nails go into 2x4 runners placed horizontally along the roof... just like any other metal roof shed.
